So I recently acquired a 2005 Joyner Sand Spider 650.
I have a few questions -
I see no timing marks on the crank pulley at all. And nothing on the block. How am I supposed to time this thing? The manual says 6 degree +/- 2 @ 900RPM, but thats all it says. No pics or info on where the timing marks are.
Also, I seem to have a timing belt, not a timing chain. Is that normal?
    • By nrggaragebuilds
    • By Cliffampranch
