2019 Coleman Outfitter 550x will not shift front axle into 4x4. I have checked fuses, replaced the dash 4x4 selector switch, removed rear of front axle housing and tested the
axle shift motor using "C" batteries and it worked both directions as it should, but when re- installed it still will NOT shift into 4x4. It has never been run off road and has 37 on it miles.   There
are 2 electrical plugs at the front axle and I am not sure which points I should be testing to rule out a faulty wire.
Any helpful ideas would be appreciated.
2019 Coleman Outfitter 550X not shifting into 4X4 - ok I removed the front axle 4wd shift motor and it continues work fine using small batteries, but
when I plug in the system electrical it still fails to operate. I did however notice that one of the electrical pins on the 6 wire plug, was not flush with
the others. I took needle nose pliers and moved the pin back into place and then ensured it stayed when re-connected to the motor.
Yup it was the electrical plug connection. Now it shifts in and out of 4x4 again. So, double check your plugs and pins....
    • By Rusmis91
      thanks in advance
    • By mrpro
    • By jertex
      I have two questions:
    • By Hoppy one
    • By chadd
      Hi all, i have a 2021 gc1k  with the tbg eng, and i am needing frt cv axles, on a review of a oem intimidator axle on ebay the buyer stated that they were exactly the same as a 08-12 rzr 800? Has anyone else ran into thiz? When i look at the 2 side by side the only diff i see is the inner joint of the oem axle looks exactly like the outer joint,but the rzr axle inner joint has the slide deep cup?
