I'm thinking about parting out my 2 Joyner's.  Both have less than 500 miles.   I would also consider selling whole.  I have titles for both and have owned them since new.   Located in northwest Florida.   I'll be in Gatlinburg , TN for Christmas if someone needs a heavy part delivered     Trooper engine has rust on the cylinders and probably won't turn over at this point due to Florida humidity.  The sand spider has a broken input shaft in the rear end, so it needs a new (cheap) input shaft and seal.   It hasn't been cranked in a couple years.  Both are complete.
14 hours ago, Buddy1113 said:
Im intersted in the joyner as well and live in florida near ocala
There are 2 of them .  Be more specific......interested in what ?   A certain part / parts ?  Buying one or both whole ?    Not much to go on except your location.
50 minutes ago, STIHLMAN said:
I'm in Monroeville,Al. and I my want one or both of these units ,but need to look at them.
Not too far from me .   Been there a few times . Harper Lee was an old friend of mine :)
you want to come look or pics ?
  • 2 years later...
    • By AlphaSerenity
      Hello,
    • By mike28honda
    • By Nick Varnes
    • By Firewalker918
    • By Hoppy one
