Was running fine low hours purchased new. Started and drove out back of the barn. Went to start it after doing some work and it will not fire. Only way I could get it to fire was to go in neutral and hold gas pedal down. Have to keep giving it gas to run.  Will not idle. Just quotes when I let it
go to idle
Hi Steve!  Similar to you, except mine only did it when it was cold(ish).  If I kept it running and the engine warmed up, ran fine.  Since temps are better since spring, haven’t had the issue.  Wish I could help you more
  • 3 months later...
I think that’s prudent.  I use only ethanol free in mine.  I partially turn the key, to run fuel pump, needle moves to far right, then I I press brake pedal, and fully turn key to start.  I then wait until the check engine light goes out, before driving.
    • By Sammy
    • By AlphaSerenity
      Hello,
    • By Silent3923
      Been waiting over a month and a half for a transmission from bobcat,  they claim the polaris transmission is different.   Can anyone verify that???
    • By OBL
    • By Hoppy one
