2021 uforce 800 turning radius is awful .
I just bought it added perfex lift
And 1.5 wheel spacers
The turning radius was bad before the lift .
I looked for steering stops under the tie rod boots and steering knuckle for steering stops . Found nothing .
Are the stops inside the steering rack ? Is there a replaced steering rack with longer throw to curb this issue ?
Any suggestions?
I need help I have a 2016 Kubota 1100 RTV my tilt steering wheel locked in the upper position after using the side release. The handle works but does not release the steering wheel to a lower position. If anyone knows and easy fix, please let me know any help is appreciated. Be Safe, Thanks!
