2016 Kubota 1100 RTV Tilt Steering wheel locked Upper Position
By rdc
I have a 2007 Joyner 1100 sand viper and before it even get's to where the thermostat opens up the oil pressure get's so low I have to shut it down. What could fix this ? I thought about adding an oil cooler with fan, thicker oil, or removing the thermostat. Any advice?
By Skeeter22
By jertex
I have two questions:
By Bucky4444
Has anyone found a decent replacement for the factory mirrors on a 2020 1100C? My 2011 1100 and 2020 1100C both have the same mirrors and Kubota hasn't made one improvement to the design during those years. Haven't checked the newer models so maybe Kubota finally woke up. Mine are definitely in need of improvement. .
By Firewalker918
