Has anyone found a decent replacement for the factory mirrors on a 2020 1100C?  My 2011 1100 and 2020 1100C both have the same mirrors and Kubota hasn't made one improvement to the design during those years.  Haven't checked the newer models so maybe Kubota finally woke up. Mine are definitely in need of improvement.  .
  • Popular Now
    • By Kakha
      Greetings to the forum participants, my Kubota RTV 400 has stopped starting. More precisely, it works intermittently. Please advise what could be the cause.
    • By fikey
      I am about 6 months in to owning my 520. It is used mainly to run back and forth to our barn and shop. Occasionally, I run it up and down a few fairly steep hills on the property. One day, as I was going up one of the hills, the motor started sputtering and a tremendous amount of smoke was coming out of the exhaust. I was near the top and it made it (sputtering) up. Once back on the flat, I made it home. I loaded it on the trailer and took it back to the dealer. They said they checked everything out and found no issues. Over the next month or so, I only had occasion to go up hills once or twice with no issue. Then one day, again as I was going up a hill, the engine sputtered, giant plume of white smoke and then the engine died. 30 seconds later, started up and made it to the top. Repeated the route (down and up) and the same thing happened again. Called the dealer and their head of service said he would come out and wanted to see it first hand. He came out a few days later and repeated the route several time and it never happened with him in it. I had videoed the whole thing on one of the times it happened to me, but since it happens intermittently, could not produce it when he was here. I told him that I had checked the temperature, the oil level and the antifreeze level after each occurrence and they were normal. I asked him to call Kubota and ask what the possibilities were and that I am not fond of it dying on the hill and blowing the smoke and I didn't want to wait until something catastrophic happened to figure it out. When I followed up, they had no answers (which doesn't exactly please me). Any ideas? The attached photo was the start of the smoking. Didn't know how to upload the video of the whole thing, but it fogged the whole area.
    • By 180gtr
      Parting out a rolled Sand viper 1100. I will list some of the parts I have, otherwise ask me if there is something specific you are looking for. I am selling everything I have for $800. I am located near Glenwood Springs CO.
      SOLD ITEMS, I do not have these items.
      Wheels
      Tires
      Engine
      Transmission
      Axles
      Shocks
      Control Arms
      Things I have....These all came off of the running engine. I have video of it running if anyone needs to verify that.
      Throttle Body $90
      Starter $150
      Alternator $150
      Fuel rail, injectors, fpr $100
      fuel pump $70
      Map Sensor $50
      Full set of Guages $150
      Exhaust w cat, O2 SOLD
      Ignition Coil - SOLD
      Wiring harness and ecu SOLD
      Radiator, shroud, elec fan, overflow tank $200
      Fuel tank w sender $150 Has dent at base of fuel neck, no leaks
      I have a box full of misc bolts, nuts, etc.
      I will sell the Chassis or Frame alone for $200. The chassis is in pretty good shape, needs some cage repair and 2 areas straightened where control arms mount. If anyone had an automotive frame machine it would take a few hours.
      That would include....
      Brake calipers, lines, pedal, master cyl, E brake assy,
      Steering shaft, wheel
      Ignition switch, key
      Light bar frame, 2 lights
      misc hardware, spindles
      2 hubs, rotors
      Engine mounts
      Throttle pedal, cables
      Shifter, cables
      Clutch master, pedal
      I am sure I am forgetting something.
      I am parting this out of ebay right now, I just picked up another project and could use the room. No I will not take less than $700 for all of it or $200 for the frame. I do not need to sell it, I will make far more parting it out but would like the extra space in the garage.
      If interested I also have an 07 1000rr engine setup I would sell with the buggy for $650.
