  • 4 weeks later...
    • By Ironhorse
      Purchased a new, leftover 2025 Bighorn Timberland 450LX.
      Dealer says to change the engine oil and transmission oil at 10 hours, then oil change every 30 hours.
      The manual says first oil change at 25 hours or 200 miles, and first gear oil change at 1900 miles.
      Are they being extra cautious?
    • By Fritz GSD
      Hello everyone. Im a new member to the board but have owned a 2016 Honda Pioneer 1000 for 3 years now. I also just bought a 2025 Polaris 570 SP NorthStar.
      I will be asking a lot of questions.
    • By Tommy2bits
      Just bought a brand new 2022 (NOS) Sector E1 with Lithium upgrade. (Single 135ah/200amp continuous). I've climbed a moderate hill in my woods probably 20 times since buying it. Today It won't climb it unless I am in Low. In High it almost makes it and then completely dies and I have to roll back down the hill. In Mid range (Max Range) I can't get 2 feet up the hill and the power output in only 100 amps, I have climbed this hill in every speed before many times. I put it on the trailer tonight and it wouldn't even get on the dang trailer in mid range. Torque is gone. That being said, when I am just cruising around in Midrange, it runs absolutely perfect with plenty of power. The only thing I did was charge it up, that is all. I charged to 100% using the charger that came with the battery. Before you think the BMS is shutting down due to overcharge protection, remember I am going UP hill so there is no regeneration AND I have done it before at 100% charge AND another big problem is that after 1 mile it is already down to 85% so it's not over charging and why is the battery draining so fast when I got 27 miles before. Battery output is fine in Low it pulls 200 amp up the hill just like normal so that doesn't point to the battery being the issue. All the individual cells on the battery are in line, so there is no dead cell either. I am tech savvy but to toward electric motors and I tried to cover all my bases. Please don't tell me basics like torque is reduced in High and Mid. The only thing I can think of is that I smelled something when I took my first drive today and I thought it was the Ebrake dragging but there was the correct amount of play in the cable and I jacked up the rear wheels and they spin freely. maybe something burned out in the motor, I do not knowm still runs great, we'll see if I have any trouble on the hills at the lake house this weekend. Maybe this is "Normal" and the settings were off before and was giving equal torque for whatever reason instead of 50% in Mid and 70% in High like the manual says....
    • By Greenb69
      Had a Kawasaki Brute Force 750 and really enjoyed riding it. Back finally gave up so got a used Wildcat Sport XT 700. Had to enlarge the trails on my property to accommodate the SxS but worth it. Never been around SxS before so big learning curve. Anything that I can learn about my Wildcat from you guys will be greatly appreciated.
    • By Bigmountainrider
      Hi Team,
       I'm new to the Forum, and I'm looking for your help. I have a 2009 Yamaha Rhino 700 that has stopped consistently charging. Here are the specs and Info I can provide, the Stator and Regulator are new. The Stator does not have continuity to ground on all 3 wires at the engine bay plug. The stator puts out 15-17AC/V at Idle and 38-39AC/V at 2000rpm at both the engine bay plug and the regulator plug. The Battery regulator plug has Battery DC Voltage, when Running the regulator puts out Charging voltage 13.4-15V. I have upgraded/added ground wires from the primary battery to the engine block, from the stock ground wire bolt on the engine to the Chassis and from the secondary battery to the regulator grounding bolt/ground wire. Now the symptoms are it Charges when first started and will continue to charge while driving or at high idle until the machine returns to idle- it will not charge after that, this includes any RPM. If your shut the machine off and restart the process restarts -it will charge until returned to idle. The Machine has and RM Stator and Regulator and a Kimpex Flywheel. The last time it was driven it had an overheating event- unrelated to charging I think, but worth the mention.
      Any thoughts would be helpful, I have the factory Regulator- it was working at the time of replacement- when swapped the same issues occur.
