Purchased a new, leftover 2025 Bighorn Timberland 450LX.
Dealer says to change the engine oil and transmission oil at 10 hours, then oil change every 30 hours.
The manual says first oil change at 25 hours or 200 miles, and first gear oil change at 1900 miles.
Are they being extra cautious?
First change at 10- yes. Filter too of course. Every 25-30 after that is fine. Make sure you use oil which is JASO compliant   Don’t forget to put a squirt of grease in everything at each oil change. I also change my fuel filter every other oil change. Don’t know where you live, change your air filter annually. More if you drive it year round or in dusty environments.
Have fun, enjoy your machine and welcome to the forum
Pop Bob
    • By nrggaragebuilds
      2004 250DL DIRT DEVIL. Hey y’all, I already know this is a long shot. But I am looking for a the “prick gear” assembly that makes reverse work for my external reverse gearbox. OEM PN D250.08.103 and its assembly. I bought the kart as a basket case, but I saw that the reverse box was present so I was optimistic.  Upon starting working on the buggy I realized there was a block off plate in plate of there the normal gear would be. If my understanding is correct that means the transmission no longer has reverse gear. I figured it’s just a standard bevel gear and I could probably find a gear to make work, but I don’t want to spend the time making all the other housing parts to shim the gear perfectly. Has anyone spare parts, or figured out an aftermarket solution from McMaster? I already know it’ll be a challenge to get this box to be happy again, but figured I would ask
    • By AlphaSerenity
      Hello,
    • By Silent3923
      Been waiting over a month and a half for a transmission from bobcat,  they claim the polaris transmission is different.   Can anyone verify that???
    • By dilger
      Transmission vent leaks oil out of it after using
