Whiplash racing Round 6
By Cliffampranch
I have a 14 mile round trip on level roads to reach the property where I work with my 2025 Amp Crew Ranch (purchased, April 2026). That 14 mile round trip uses 60% of the battery as shown on the gage for a calculated range of 23.3 miles versus an advertised “up to 50 miles” range. A mile or two working on the property gets me a flashing gage and warning beeping by the time I get home. The dealer was good to work with and even with a new battery (yesterday) the results were about the same, although there seemed to be more power and a higher top speed. I own a Mach-e Mustang so I am familiar with how various conditions affect range, but less than 50% of advertised range just seems like there has to be something out of whack.
Now I’m wondering if there is a controller and/or software issue affecting the range and performance. At various points the Amp seems to lose power for no reason and then has trouble maintaining speed. Any ideas?
Also, twice now, the brakes seem to have not released fully. After noticing reduced speed, I stopped and check the rotors and wheel…..HOT! So, now every time I feel less power, I stopped to cycle the brakes and check the temperature. Very annoying. Are there any adjustments to be had?
Lastly, while an electric vehicle powertrain is quiet, my Amp was horrible from a road noise and vibration standpoint. This was easily fixed by locating panels vibrating on other panels or the frame (even the cup holders were vibrating) and installing felt adhesive pads at the contact points (seat to frame, windshield to frame, fenders to frame, etc.). This is a $10 and 1/2 hour fix that makes a significant improvement in the driver/passenger experience. Tire noise, yes, but that’s because of the knobby tread.
By Pop Bob
I had been driving for about 15 minutes, everything fine. All of a sudden the engine was surging, losing power, would run with 1/2 throttle or greater and was backfiring badly. Luckily I was close to home and got it back. The tipoff to me was that I thought I was hearing intake noise. Sure enough, the rubber boot which connects the air cleaner and intake piping to the throttle body came loose. Obviously the computer was confused. It turned out to be an easy fix, but this is now added to my inspection list. Just thought this might help someone else.
By Xov
By Davescat
I have an 2019 Caterpillar cuv85. Which is the same as the prowler pro and the tracker800sx and prob many more. What is everyone doing for a lift? I need more ground clearance. I have seen 1 lift available. But is this the only thing I can do?
By KMP
We just bought our 1st side-by-side and wanted to get tips on maintenance items we should address immediately for our 2015 Arctic Cat Wildcat Sport 700 XT. We are truly beginners and welcome any and all suggestions. Thank you, we appreciate your help!
