d1105T install in rtv 1000?
By rdc
I have a 2007 Joyner 1100 sand viper and before it even get's to where the thermostat opens up the oil pressure get's so low I have to shut it down. What could fix this ? I thought about adding an oil cooler with fan, thicker oil, or removing the thermostat. Any advice?
By Sammy
By AlphaSerenity
Hello,
By mike28honda
