2022 Coleman 400 with 13 hours on the engine and the mice got to it. Every wire coming out of the steering column in one cluster has been eaten through. I tried reconnecting matching wire colors to each other and I get the left turn signal and hazards to work, nothing else. If I play around a bit I can get the horn to honk or headlights to come on but only when I connect them to the brown wire. Obviously I don't know what I am doing here. Does anyone have a picture of how these wires are connected when they are under the hood on the drivers side coming from the steering column?
Gray - seems to carry power
Brown - left turn signal
Pink with red stripe - horn?
Green - head lights?
Yellow - head lights?
Yellow with red stripe?
Blue?
Dark green?
    • By Skeeter22
    • By Rusmis91
      I’ve never been around Coleman Utv machines. Do they have a good reputation, durable dependability. Could you compare them to yamaha rhinos or Polaris ranger
      thanks in advance
    • By mrpro
      I got the fronts adjusted.  I'm trying to raise the ride height in the rear, but my spanner wrench keeps slipping.  Is there an easier better way?  It's like there's too much pressure working against me to be able to twist the height adjusters.  How can I relieve that tension to make them easier to turn?
    • By OBL
    • By Jeff freeman
