Tie Rod Front Sway Bar - AXIS 500
By Ike
It went you that hill for 4 years and now it gets about 25-30 feet up the fairly steep hill and the wheels stop turning, although the engine still revs, and same problem in reverse, forward, or 4WD mode. Dealer (Fuller's of Antigo, WI) says it can't replicate the problem driving into and out of a ditch, or up their loading ramp so they gave up.
What could the problem be? Only abut 400 miles on it, if that. Fluids are OK.
By AlphaSerenity
Hello,
By OBL
By mike28honda
By Nick Varnes
So I have a Bennche Bighorn 500 that I bought used a couple years ago. Was working fine until this winter when I was plowing and I think it drained the battery. And had a difficult time starting and staying running. Idle seamed really low, and would only stay running if I pushed on the throttle. So I changed the battery, and the acm valve, fuel filter and spark plug it will start up and surgery to 3k rpm but comes back down and dies, unless I give it throttle. I am getting fairly good amount of fuel from fuel pump. It does spit at stutter right before it dies. What should I try next?
