Coleman Outfitter 550x alternator capacity
jmutv
Go to solution Solved by aefron88,
Hello there!  I am looking at adding some accessories to my 2021 550x like lights and a cab heater.  I was wondering if anyone happens to know what the alternator amperage capacity is?  More specifically I suppose is how much extra capacity above the stock draw is with lights on etc.  I want to be cautious not to draw too much.  Googling for it didn’t return anything useful.
  • Solution
I've never seen a spec published anywhere, maybe someone will chime in.
I doubt theres enough overhead to run an electric heater that puts out enough to be worthwhile. My experience with these types of things is there might be 10-15 extra amps of overhead MAX at idle, quite possibly less. A 100 watt light bar will eat half of that. A 100 watt electric heater would eat the other half and isn't going to heat the cab.
If you feel like experimenting you could keep adding load until the battery voltage is <14V at idle, that will give a good idea of the max limit. Dont forget to turn on the factory lights (35W ea), brake lights (10W ea), turn signals (10W ea), etc as all that has signifigant draw.
  • Thanks 1
I would suggest you go with a heater that uses a heatercore for the heat, the only electrical draw-is from the fan. plenty of heat and You cant see any effect when the fan is running such as dim lights etc. Kits are fairly pricey ($399) for the Ice Crusher I bought, but if you are really handy, you could do an install from generic units on ebay and the like.
  • Thanks 1
Thank you both for your replies!  I didn’t mention in my original post, but this Maradyne Is the heater I purchased: https://www.zoro.com/maradyne-hydronic-heater-12v-2-speed-80-cfm-hf-100012-m/i/G0139120/. I kept going back and forth between it and the next step up: https://www.zoro.com/maradyne-hydronic-heater-12v-2-speed-177-cfm-hf-200012-m/i/G0139087/?recommended=true
I’d like to install with purchasing an enclosure in a few months.  I appreciate the input!
    • By doncaron
      Hello everyone!
      First of all I would like to thank you for the help with my timing problem, it was the chain. Now I’m looking for the part number for the wet clutch baring.  I’ve been looking for it but my side by side is a 2022 t-boss 550 and it’s not the same as a 2021. Can anyone help me please?
      thank you in advance again.
    • By Mark M
      Hello, Hope someone can help driver side cv axle broke anyone know of aftermarket ones you can get, I have 40 Hours on the machine and don't want to pay 450.00 for a new one from cub cadet but I can't find anything after market
    • By buckrub
    • By Anthony Vigil
      Can anyone tell me how they grease the drivelines ?  Can’t grease the u joints. Do you need to take the driveline off ?
      And are they easy to take off?
    • By tim hughes
      does any one else have a slipping belt on the hisun ...i put new wet clutch one way bearing new belt, cleaned primary and secondary and still get slight slippage
