I'll have to get some pictures this weekend of what I did.
I used a glowshift GS-TCD06 gauge along with mounting bracket GS-U1UDB. The raditor hose T I used is in the thread I provide purchased on Amazon. I did bore the center of the T adaptor some because I didn't want to restrict the coolant flow. I also drilled and tapped the adaptor to accept  a  1/8" NPT to 1/4" NPT reducer to keep the temperature sensor from filling up the inside of the adaptor.
Here are the pictures as promised. The fuse block is well a fuse block connected to the battery, and the terminal strip is connected to switched power. The picture of the adaptor shows how I drilled tapped to a larger NPT thread to raise the sensor out of the direct coolant flow. I contacted Glow gauge tech support and they said it was perfect.
17 minutes ago, Hollywood said:
Thanks looks great. Doing it just the way you did.
Also, forgot to mention I placed the sensor adaptor in the top hose. You can see when the thermostat opens and closes. I used two clamps to pinch the hose and didn't lose  any coolant.
    • By Firewalker918
    • By Timbo
    • By Sharon
    • By Razorair
      New to this site I just got this 2014 Coleman UTV 700 High Temp Light on from the start cold I haven't really ohm checked the sensors although they are all new but I have done lots of work on the engine I've replace the head gasket, wet clutch rebuilt the primary clutch and cleaned the secondary clutch with a new belt plus a bunch of other stuff I just can't figure out this high temp light that is on at start and has never been off.  I have bled the air multiple times.  I also wired a switch for the fan to run it most of the time due to others that have suggested this. It is running good the radiator is getting warm but really haven't ran it enough to make sure it's not getting too hot but I just want the light to work as it's suppose to.  I would really like to install a true temp gauge if anybody could help with doing that.
    • By mac66
