2012 Bennche Bighorn 700x starter/solenoid problems
By Gerald Dillman
By D MAYNARD
Thank You,
D Maynard
By tuell
Hi everyone I have a 2016 hisun vector 550 with 1320 miles on it I recently replaced the clutch the bell the belt the one way bearing basically everything inside the primary and drove approximately one mile my side by side just stopped pulling... no noise no smoke nothing the belt is still good but it's like the transmission will not engage in any gear any help would be greatly appreciated.... I have lifted the rear end and started the side to side put it in gear Wheels do not move but you can turn them by hand
By bms stallion owner
hello, my BMS Stallion 600 is having accleration issues. the manual fails to show final gear oil diagrams very well... I have the owners manual and suspect issue is associated to transmission , I want to check the level of the gearoil. I located a drain plug (but not the fill plug nor dipstick). It will run - but wont exceede 2mph. Troubleshooting suggestions or comprehensive manual suggestions? Thanks
