New AMP Pro Owner
By donwan
I have a part that fell over to the exhaust and burned the harness up. I can't figure out what it is. Does anyone know what the start relay looks like? The part I can't figure out has 4 wires, a red power, a green and brown wire, a black and unsure what the 4th color was. Anyone have a clue?
By Randyh79
Does anyone know how to adjust the headlights on a 2024 Hisun sector /Bad Boy Bandit 750? The high beams are where the low beams ought to be.
Thanks Randy
By MOTORHEAD1959
ATV just clicks when trying to start. Battery is good, has a new starter, and all the wiring looks good. any suggestions on where to go from here? thanks
By malenurse13
We just bought a used 2017 American Landmaster TW450. No hour meter that I can find, so not sure exactly how much it has been used.
The first 2 days we had it, the starter was a little sketchy, but it started after 2-3 tries. Sometimes when turning the key, we would hear a loud metal "clink" sound. Like the starter made contact, but didn't have enough power to turn.
THIS MORNING... Turning the key, we hear a single click sound. That's it. Even with a new battery, the starter is still doing the same thing. Both batteries (old and new) were reading 12.8 volts on volt meter. So I'm wondering what else could be going on? Any ideas on what to look for would be greatly appreciated...
Thank you!
By aefron88
I've seen a number of requests for the location of all the grease points on these machines, and there is no definitive list in the manual. This covers the UT400, but other Coleman/Hisun models should be similar.
Tools:
First to grease your machine you need a grease gun and some NLGI#2 grease. You will find it helpful to buy a needle attachment as pictured here, due to poor clearance on some of the U-joints. The rest of the zerks use the standard attachment.
Technique:
Wipe any dirt/grease off the zerk before greasing to prevent pushing gunk inside and causing excess wear.
Push the grease gun on the zerk at a straight angle and give it a few pumps. You will hear an oozing noise or sea grease coming out from the outside of the greased area when you've put enough grease in, a few pumps should be plenty.
If it's just oozing around the zerk you either don't have a good seat with the gun, or the zerk may be rusted and the check ball frozen. Try seating it again and regrease.
Wipe up any excess grease when youre done to prevent making a mess.
Greasepoints:
Rear A-Arms are greasable with the wheels on from the rear, I took the picture with the wheel off for easier visibility
That's it. All other Hisuns should be substantially similar.
