Coleman 550 rattle/knock with engine running idle
jmutv
Hello there!  I hear a low rumble/rattle when it’s just sitting still with the engine running idle.  Has less than 20 hours of run time.  Have a listen to the attached audio.  I don’t if this is normal.  Slightest amount of gas and rattle goes away.  All in neutral.  Shifting transmission changes nothing
Edited by jmutv
Reloaded with wave file
  • jmutv changed the title to Coleman 550 rattle with engine running idle
  • jmutv changed the title to Coleman 550 rattle/knock with engine running idle
    • By Greg Kilgore
    • By Jeff j j
      I have a 2023 trailboss 750. It has a low rpm and mid rpm miss that won't go away. Took it to a shop and had full service, valves adjusted and a sensor replaced. Think the miss is worse than before. Any ideas?0
    • By AlphaSerenity
      Hello,
    • By hdtran
      Hy (pronounce he), just bought a Hisun Sector E1.
      I'll be using it to haul logs and stuff in the Sangre de Cristo mountains.
    • By nods
      Less than 40 miles can barely start. Dealer is working with Hisun on a number of other issues on this UTV. Can not get clear info on the meaning of these E codes this is getting. Anybody have some clear info for me?
