SideXSide Mania....gotta liquidate the couple thousand blems I have so I'm blowing them out for $5 plus $4.95 shipping.
Here's whats wrong with them. A couple of menu buttons don't link up to the right segment and the SideXSide Invitational loops towards the end of the segment, you just need to fast forward or next chapter to the next segment.
The whole movie is there, just need to hit the ff or next chapter button once.
Shipped in a clear case.
PayPal $9.95 to [email protected] or call me and I'll get one shipped right out!
Greg 406-459-5531
    • By TPlummer
    • By Kingfish
    • By Grizz
      hello grizz again I keep blowing this fuse left side on bottom it’s a 15 amp I have checked all the wires can’t find anything bare or broken it is a 2021 axis 700 I put a 20 amp in so I could pull out of shop to take pictures. Does anyone have any suggestions. Thanks.
