First you have to remove the u-joint under the dash. Then unbolt the 2 bolts that hold it in place, also under the dash. This requires removing the front hood/deck. A lot of us have ours hinged to make getting access to this area easy. I must have opened my hood hundreds of times now so I', real glad mine is hinged. I use the little rubber T handled bungies that the big trucks use to hold the front down.
I,m wanting to take that shaft out of that bracket
There is a snap ring near the bottom side of the shaft that holds the shaft itself into the tubing is turns in. Remove the snap ring and with a bit of tapping it should come out.
