FOR SALE 2007 Joyner 1100 Sand Viper
2007 Joyner 1100 Sand Viper $8000
1100 cc Chery engine
4 cylinder
16 valve
dual overhead cams
Electronic Fuel Injection
86 hp
11 gal gas tank
over 40 mpg
4 speed w/reverse
disc brakes
5 point harness
turn signals
street legal
Additional added:
new 30" tires and 15" wheels
new swing arms, boxed
new rear bearings
radio
cb and antenna
spare tire rack
new rear springs
windshield with tinted glass
new throttle cable
new clutch cable
new open rear differential
new rear axles
new cv joints and boots
Bruce
714-743-3595
[email protected]
Located in Quartzsite, AZ
  • 2 months later...
  • 2 years later...
    • By LongSun
    • By NDV45
      I have  2008 Cub Cadet Volunteer Tracker.  Was running fine, parked and next morning electric fuel pump inop.  Checked voltage had 4.2 volts.  Swapped relays in fuse box, checked all fuses (good) and still low voltage.   Does the ECU control the voltage to the fuel pump or which relay controls the voltage to the pump?
      Have checked all wiring and not found any place it could be shorted (not saying I may have missed something). I am at a loss.  Need Help Please.
    • By CYJSP2009
      Dear Joyner owners
      3. Cables,
      4. Brake parts
      5. Engine parts
      6. Other parts.
      Have a good weekend
      Casey /  Leaf Asia
      2023-11-17
    • By Pilot1996
      When researching the Tracker, I was interested in the 800SX LE. The original sales literature indicated that the LE came with 27x9x14 and 27x11x14 tires. When I went to pick up my Tracker, it had 26” tires on it. I called Tracker before paying for the Tracker and was told they had supply issues and could not get 27” tires. I’m curious to know if anyone has taken delivery of an LE with 27” tires in stalled? I just recently installed 27” tires and am happy with the added ground clearance and beefy look the machine has taken on!
    • By CYJSP2009
      Dear Friends,
      Buy 1 piece: Get 5% discount,
      Good Luck
      Casey / Leaf Asia
      July-07-2022
