I must say that so far I have not been very impressed with the aftermarket parts availability, or the distributors responsiveness to issues that I have raised.  Having said that, I cannot make a comparison to other brands as I have no experience with them. There seems to be a very healthy aftermarket part availability for the major brands (Polaris, Can-AM, Honda, Kawasaki) but they also have a lot larger market share.  I am disappointed with the interactions that I have had with Kymco-USA so far, however as a BMW motorcycle owner, I am used to the business model that denys all issues until they cannot any more.
Put me down as a "wait and see if they become more responsive to their customers" ......
    • By JohnnyB
    • By BWF
      I am at a loss, please help!
      Brad
    • By Burk
    • By Jamie 67
    • By Sharon
