I have a 2011 or so Landmaster LM200.  I cannot get it to start.  I turn the key and nothing happens.  The brake switch seems to be working, the ignition switch works.  The Coil is new the Voltage Regulator is new and the starter relay is new.
I can connect the terminals on the starter relay and it starts right up and runs fine.  I just can't get it to start by turning the key.
I am having a bit of trouble bleeding the brakes, not much fluid comes out at the calipers when I am pumping the brakes, though that an air bubble near the brake switch might make it not sense that the brake pedal is depressed.
I am at a loss, please help!
Brad
Have you got it working yet?
I was thinking it may be a safety switch that is really doing its job too well. I have a newer-ish LM and the gear select has a safety switch so I can't start it in gear.  I don't have an ign/ brake cut off safety switch in mine.
 Maybe trace out the starter lead to see if it has broken or worn on something and isn't getting the start signal. Key to relay. Connections at the key loose/dirty? Is there power getting to the relay from the key? Key switch bad?
 As far as brake fluid, it's really not that old but sometimes on older vehicles the rubber hose's going to the brakes can harden and swell inside and block the fluid.
 American Landmaster website has a lot of their rigs still listed with manuals and the like, you might try downloading them and see if you can find the safety ign cutout sensors and if they have any trouble shooting things to try.
    • By OBL
    • By mfitzner
      Cranks after installing a jumper wire to ignition switch to get power but will not start
      Have spark and fuel pump runs
    • By Jeff freeman
    • By JohnnyB
      My Massimo 500 will not start. I’ve checked all the obvious things. It turns over just fine. fuel, spark, fuse box are all good. I can’t figure it out. Any ideas would be greatly appreciated. Thank you.
    • By Garjess
      My rtv 1140 won't turn over.  I've jumped the neutral switch, and the brake switch, and checked the ignition switch. I'm not getting any power to the trigger wire on the starter solenoid.  It starts fine with the key on and putting power to the trigger wire on the solonoid.
      Does a 2010 RTV 1140 cpx have a starter relay?
      Does anyone have a wiring diagram?
