Hey everyone. I am trying to find information and ideas on a cargo trailer a UTV can tow. The UTV max towing is 2500 pounds. I need a enclosed trailer that can carry supplies over off-road terrain. It can also be a open trailer. I don't need it to have any special options on it. Just light weight and the ability to carry up to 2500lbs.
    • By Joe Rizo
      Hello All,
      1. Fuel pump (new)
      2. Fuel sensor (new)
      3. Fuel injector (new)
      4. Battery (new)
      6. fuses (12v to all)
      13. replaced air filter
    • By hetovi
      Hey everyone,
    • By KWinTX
