    • By AaronD1982
      Next problem with charging system to tackle, any help would be appreciated.
      New starter solenoid....check
      New Voltage Regulator...check.
      Dynamic test to Stator.....bang...pulling like 2 Volts AC
      Problem: Without pulling the part out and stranding the vehicle at the shop forever.... I am trying to find the correct stator or at least one that might not be exact for the Massimo Buck 400S, but fit and connect and do the job if that makes sense.... if anyone has any ideas, please shoot them my way.
    • By Dave Jones
      So with seat belt on  I can only get up to 20mph then it starts bucking until I get under 20 again. Diconnected the seatbelt and same thing. Reconnected seatbelt and unplugged speed sensor. Zoom..it flies. But now I have no speedometer. I have a new speedometer sensor on the way..any other ideas?
    • By Mitch13
      2022 Coleman 400 with 13 hours on the engine and the mice got to it. Every wire coming out of the steering column in one cluster has been eaten through. I tried reconnecting matching wire colors to each other and I get the left turn signal and hazards to work, nothing else. If I play around a bit I can get the horn to honk or headlights to come on but only when I connect them to the brown wire. Obviously I don't know what I am doing here. Does anyone have a picture of how these wires are connected when they are under the hood on the drivers side coming from the steering column?
      Gray - seems to carry power
      Brown - left turn signal
      Pink with red stripe - horn?
      Green - head lights?
      Yellow - head lights?
      Yellow with red stripe?
      Blue?
      Dark green?
    • By AaronD1982
      I recently purchased a 2019 or 2020 (no manual) Massimo 400S Buck Series UTV.  It ran fine for a couple days but the low battery light was flashing while it drove.  It then died in the field one day and I was able to jump the battery and get it rolling enough to get back to the barn.  It started both times I turned the key for a couple days after and when driven died 10 minutes later in the driveway.  Even after jumping it had no juice, but with the key out of the ignition it kept trying to start, a quick look on the Google machine and it suggested starter solenoid or ignition switch was the culprit.  Fair enough, let's just order a replacement solenoid, right?  No way Jose....the pin connector on the UTV is a 2-pin white plastic connector and the part received is a 4 pin.  How do I swap that and make it work?  Can I even?  Where do I find correct parts in the future?
    • By RBonds007
      I bought this SxS brand new.  A couple of years after I bought it, I became disabled.  Thus it has only 47 miles and around 16 hours of use.  I have no need to keep the SxS.  I am in Foley, Alabama.  It is very hard for me to get in out of the Challenger.  I would like to sell the set, 2019 Challenger 400, trailer and uninstalled winch (this was bought brand new as well, someone was supposed to help this newbie install and we never got around to doing this). I want  $6500 for the whole set OBO (Serious offers only).
