You can post now and register later.
If you have an account, sign in now to post with your account.
I have an 850. It’s been overheating. The electric fan is not kicking on. I see the temperature switch going into the radiator, but there’s no wire plugging in to it or none to be found in the area. i’m thinking I might’ve hooked on a branch and it ripped out the harness on that part. Does anybody have a picture or no where that plugs into on the harness? On the top of the firewall, I did notice some plugs that have nothing plugged into it. I was wondering if it’s a harness that goes from there down to the radiator that was pulled off
Hope I posted this in the right place. Looking for the left side shaft carrier where the rear bearings go for an 1100cc sand viper, I understand an 800 cc carrier will also work. I need the old style two bearing with the spacer in the middle, the new style with just the one wide bearing wont work. If anybody has one I'll buy it right away. my email is [email protected]
I have a AXIS 700 EFI Fuel pump pressure stays at 40 psi and when return line is blocked the pressure goes to 60 psi. and wll only run with return line closed.
