Have a Coleman 2021 ut400rt 234 miles on it purchased last year from a person who won it in a drawing,p was not giving away until 2024 late, did not realize the running lights not working checked all fuses everything good double filament bulb one filaments light up with brake, turn signals fine front and rear headlight everything okay just no rear running lights, could it be in the light switch, thank you in advance for any help
    • By Rusmis91
      I’ve never been around Coleman Utv machines. Do they have a good reputation, durable dependability. Could you compare them to yamaha rhinos or Polaris ranger
      thanks in advance
    • By Sammy
    • By mrpro
      I got the fronts adjusted.  I'm trying to raise the ride height in the rear, but my spanner wrench keeps slipping.  Is there an easier better way?  It's like there's too much pressure working against me to be able to twist the height adjusters.  How can I relieve that tension to make them easier to turn?
    • By Mountainman
      Radiator fan on 2018 textron havoc won’t come on
    • By mehe
