I’m working on a 2011 Bobcat 3400. At around 20mph it bogs down and loses all power. If you let off the gas and let it slow down, it’ll go again until 20mph.
It use to not do this. Use to run 30mph+ no problem. I’ve replaced the fuel injector, fuel pump, spark plug, and air filter. Cleaned the throttle body, the fuel lines, and cleaned the fuel tank out.
What am I missing? Any help would be greatly appreciated.
  • Ztmartin96 changed the title to 2011 Bobcat 3400 Bogging Down
    • By Sammy
    • By jertex
      I have two questions:
    • By Silent3923
      Been waiting over a month and a half for a transmission from bobcat,  they claim the polaris transmission is different.   Can anyone verify that???
    • By Hoppy one
      I replaced the stator on our Bennche 500 because it was not charging. It ran as long as you kept the battery charged. I replaced the stator now it’s not firing. The only problem I found was a wire in the new stator for the crank position sensor was in the wrong place in the plug. I switched it around but still no fire. Putting a meter on those wires and cranking the motor showed no voltage from the crank position sensor. Something I did or a bad “new “ part? Thanks for any ideas.
