Does anyone know of any decent guides to do service work?
Looks like there's a huge sheet metal plate that has to come off to do an oil change.  If it does it will be getting an access port cut into it such that I can reseal.
I also would like to get to air filter, but the manual link provided here doesn't seem to apply.
There's a service manual that exist, but it doesn't have the nuances for this latest year and model.   I can tell you contacting Kymco USA is pointless, and the website is dated.
I decided that having to take that shield off just to do an oil change is going to be a total PITA and make me an angry boy every time I do.  And I do plan to change oil often considering how hot these runs.  I considered making an access hole where plug is but that's bound to get messy.    I'm going to use an oil extractor for oil changes and depend on my "foreign car" knowledge for what doesn't make sense with existing manual.  I too am retired and live in a log home on a mountain deep in the woods.  I'm the "English" among the Amish.  There's a lot of dirt roads here, so it gets dusty.
Doesn't seem to be any really active forums for Kymco UTVs.
I'm surprised considering they make a lot of parts for Honda.
  • Popular Now
    • By Rmillerdesigns
    • By Timbo
    • By Sharon
    • By Outlaw Redneck
      Hello all. I have a 2005 Joyner sand spider 650 with the dreaded broken output shaft on the transmission. I got ahold of a 2007 joyner commando 650 for cheap that had a bad motor but a good transmission. I got it because everything i read said that the transmission would work but it seems that it will not. Due to the commando being 4x4 it has a selectable locker and a small ring gear using a "idler" gear to turn the ring gear which make the output spin the wrong direction. Is there any way that I can make this thing work? I really dont want a commando,  I like the buggy but if the trans wont work then I can only put my motor in the commando. Any help would be appreciated. I have the ring gear from the original trans but the shaft is broken and the shaft from the commando wont fit the ring gear it doesn't appear.
