I have a massimo 500 with a blown motor and want rid of the rest of it . Is that ok here ? Motor is in a box , has low hours on the machine be a good parts machine for someone or stick a  different motor in it . Tires are good body looks like no use on it . 500 bucks takes it away  . 918-479-4200 located in NE Oklahoma .  Red
    • By Adrian Domingues
      Thanks for your help
    • By AlphaSerenity
      Hello,
    • By mike28honda
    • By Nick Varnes
    • By Hoppy one
      I replaced the stator on our Bennche 500 because it was not charging. It ran as long as you kept the battery charged. I replaced the stator now it’s not firing. The only problem I found was a wire in the new stator for the crank position sensor was in the wrong place in the plug. I switched it around but still no fire. Putting a meter on those wires and cranking the motor showed no voltage from the crank position sensor. Something I did or a bad “new “ part? Thanks for any ideas.
