Coleman UT400 Coolant Leaking
Go to solution Solved by NewtoUTV,
I just reassembled the engine to fix the shifting issue.  I ran the unit for about 15 min and it started to overheat.  I thought it was an air lock and let the unit cool down and opened the radiator cap and head burping and then looked under the machine to find coolant.  I found where it is leaking from, see attached photo 1.  I added coolant and it doesn't leak until the fan starts.  When I put the engine back together I may have installed something incorrectly? Image#2 one shows a part that I was not sure where it goes, I ended assuming it was part number 23 in image #3.  Is this correct?  Could this part be the issue why I am getting leaking?
attached photo 1
image 2
image 3
  • Solution
So the leaking is because part 23 is damaged and had come apart when I took off the Impeller to clean it.  my bad for not paying attention to this when I had the engine out of the chassis.  I ordered a new water seal from https://www.motorcycledoctor.com/checkout/order-received/23632/?key=wc_order_v3q9nFrtImCjy  The delivery was 3 days, so I didn't have to wait long for the part and they are the only one I could find that had the part in stock.  Taking out the old part was a pain.  saf344g               I only disconnected the engine from the chassis along with other misc items need to be taken off to rotate the engine enough to get to the part. Also disconnected the gas tank to shift it backward so I could get in there.
    • By Nick Varnes
    • By Mountainman
    • By Sidewinder
    • By fikey
      I am about 6 months in to owning my 520. It is used mainly to run back and forth to our barn and shop. Occasionally, I run it up and down a few fairly steep hills on the property. One day, as I was going up one of the hills, the motor started sputtering and a tremendous amount of smoke was coming out of the exhaust. I was near the top and it made it (sputtering) up. Once back on the flat, I made it home. I loaded it on the trailer and took it back to the dealer. They said they checked everything out and found no issues. Over the next month or so, I only had occasion to go up hills once or twice with no issue. Then one day, again as I was going up a hill, the engine sputtered, giant plume of white smoke and then the engine died. 30 seconds later, started up and made it to the top. Repeated the route (down and up) and the same thing happened again. Called the dealer and their head of service said he would come out and wanted to see it first hand. He came out a few days later and repeated the route several time and it never happened with him in it. I had videoed the whole thing on one of the times it happened to me, but since it happens intermittently, could not produce it when he was here. I told him that I had checked the temperature, the oil level and the antifreeze level after each occurrence and they were normal. I asked him to call Kubota and ask what the possibilities were and that I am not fond of it dying on the hill and blowing the smoke and I didn't want to wait until something catastrophic happened to figure it out. When I followed up, they had no answers (which doesn't exactly please me). Any ideas? The attached photo was the start of the smoking. Didn't know how to upload the video of the whole thing, but it fogged the whole area.
