Go to start engine fuel injection spark plugs are fuel soaked popping spitting back fire constantly pumping gas pedal to keep going then once engine reaches 1st dot on temp gage it will idle and then run like a scalded dog shut it off then start it it goes back to like starting cold engine new plugs and fuel filter also cleaned fuel lines and fuel tank I'm at a loss also loses power in a pull sometimes
    • By Sammy
    • By Silent3923
      Been waiting over a month and a half for a transmission from bobcat,  they claim the polaris transmission is different.   Can anyone verify that???
    • By Nick Varnes
    • By Hoppy one
      I replaced the stator on our Bennche 500 because it was not charging. It ran as long as you kept the battery charged. I replaced the stator now it’s not firing. The only problem I found was a wire in the new stator for the crank position sensor was in the wrong place in the plug. I switched it around but still no fire. Putting a meter on those wires and cranking the motor showed no voltage from the crank position sensor. Something I did or a bad “new “ part? Thanks for any ideas.
    • By mfitzner
      Cranks after installing a jumper wire to ignition switch to get power but will not start
      Have spark and fuel pump runs
