Hi,
I have an Axis 500 2022, here's my question. Is it normal that there is a gap of a few centimeters when I press the gas pedal before the engine increase speed, as if there was a looseness? Therefore I would not have all the power.
Thanks.
  • Solution
Most throttle cables can be adjusted. Sometimes they can stretch a bit or loosen up at the cable lock. The adjustment can be at the pedal and or at the throttle lever on the carburetor.  Some you just loosen the bolt holding the outer cable part then pull it until the inner cable is tight or loose depending on what you need.
To find out if you have full throttle have someone, -with the engine off-, push the throttle pedal all the way down then see if you can move the carburetor throttle lever any farther, If it can't move it any farther then you have full throttle. If you can still rotate it a bit more then the cable needs to be adjusted. Having a "little" play in the pedal is normal.
I understand very well your solution. I'm going to try your idea.
    • By AlphaSerenity
      Hello,
    • By Silent3923
      Been waiting over a month and a half for a transmission from bobcat,  they claim the polaris transmission is different.   Can anyone verify that???
    • By mike28honda
    • By Nick Varnes
    • By Hoppy one
