    • By JohnnyB
      My Massimo 500 will not start. I’ve checked all the obvious things. It turns over just fine. fuel, spark, fuse box are all good. I can’t figure it out. Any ideas would be greatly appreciated. Thank you.
    • By BWF
      I have a 2011 or so Landmaster LM200.  I cannot get it to start.  I turn the key and nothing happens.  The brake switch seems to be working, the ignition switch works.  The Coil is new the Voltage Regulator is new and the starter relay is new.
      I can connect the terminals on the starter relay and it starts right up and runs fine.  I just can't get it to start by turning the key.
      I am having a bit of trouble bleeding the brakes, not much fluid comes out at the calipers when I am pumping the brakes, though that an air bubble near the brake switch might make it not sense that the brake pedal is depressed.
      I am at a loss, please help!
      Brad
    • By Kierobi
      Have a MSU 500 that we got from my wife's uncle a while back. We've had it running and hauling around the property but it stopped a few months ago after what I thought was running out of gas and I'm just getting to looking into it.
      Had fuel to the injector but nothing coming out the injector so swapped with new injector and installed inline filter in the supply hose from fuel pump. Tried again and still nothing but noticed this time that I can't hear the fuel pump priming.
      Pulled off the electrical connection and I'm getting 12V to the fuel pump but it won't run. Put it on a test bench and got it to run so put test lamp between +ve and -ve terminals on the connector and nothing. Checked against the passenger seat securing post and get a light.
      Tried chasing the wire back and think that the ground is through the ECU but not 100% sure. Can someone confirm for me? And if it is through the ECU, is the ECU just grounded against the frame or is it wired through to the battery?
      Thanks in advance and hope this all make sense!
    • By brewski
      I just purchased a 2025 kubota rtv 1100 x cab esd esnting to install light bars on the roof it appears to be prewired for lights how do lights mount and what kind of switches do i need
    • By Butch
      I have a AXIS 700 EFI Fuel pump pressure stays at 40 psi and when return line is blocked the pressure goes to 60 psi. and wll only run with return line closed.
