Kubota rtv x900 rebuid
By jertex
I have two questions:
By OBL
By Firewalker918
By Eman85
By Pop Bob
I’m ready to buy a second machine. I looked at a Gator and a Mule. They are larger than I want. Something more trail size will be better. That being said, I do not wish to purchase from a big box store again. Can anyone recommend a good dealer who sells Hisun based machines?
Also, any thoughts on a machine with enclosed cab, HVAC, and modern electronics
Pop Bob
