If the engine on our Sector 750 dies, as it likes to do, or if you turn it off while still in gear, while on an incline, the drivetrain locks up, including the shifter.  You can't start it because it's not in Park or neutral, and you can't shift it.  The only way we've found to free it up is to get off and push/pull/jiggle it, to remove the pressure on the drivetrain, while tugging on the shift lever.  The danger is that once you hit neutral, it takes off down the incline.  If someone was in front of it, they'd get run over.  The other day, it was a tree down the hill that stopped it.  I filed a CPSC rreport.  Very dangerous!!!
    • By nrggaragebuilds
      2004 250DL DIRT DEVIL. Hey y’all, I already know this is a long shot. But I am looking for a the “prick gear” assembly that makes reverse work for my external reverse gearbox. OEM PN D250.08.103 and its assembly. I bought the kart as a basket case, but I saw that the reverse box was present so I was optimistic.  Upon starting working on the buggy I realized there was a block off plate in plate of there the normal gear would be. If my understanding is correct that means the transmission no longer has reverse gear. I figured it’s just a standard bevel gear and I could probably find a gear to make work, but I don’t want to spend the time making all the other housing parts to shim the gear perfectly. Has anyone spare parts, or figured out an aftermarket solution from McMaster? I already know it’ll be a challenge to get this box to be happy again, but figured I would ask
    • By AlphaSerenity
      Hello,
    • By jertex
      I have two questions:
    • By mfitzner
      Cranks after installing a jumper wire to ignition switch to get power but will not start
      Have spark and fuel pump runs
