Hisun cvt drive belt?
By AlphaSerenity
Hello,
By Kyler
Put new fuel in this thing, new battery I can get it to turn over but want stay running it’ll try to run with starting fluid but shuts right back off what could the problem be?
By HISUN Sector 750 EPS Failu
"Mrs. Smith" doesn't like how loud our Sector 750 is. On a HISUN forum someone said the same thing about his 750. I haven't given it much thought because I've been more focused on stuff that has broken.
So, I used my decibel meter to check ours out. 4000 RPM, Low gear, under 20 MPH . . . . 97 decibels. That's above most ordinances, even state boat noise limits.
AI Overview Ninety-seven (97) decibels is considered very loud and dangerous to hearing with prolonged exposure, roughly equivalent to a newspaper press, a loud nightclub, or a snowmobile. At this level, damage can occur after just 30 minutes, necessitating hearing protection -
By Firewalker918
