I need shifter cable for my 2008 joyner renegade 800 can not find a place anywhere to get one.someone told Me that John deer parts will fit on joyners .is this true?
  • 4 months later...
The major issue with Joyners is scarce parts support stateside.  John Deere uses a CVT on their 825i - no gear shift cable that I know of that works on the Renegade.  The shift cables have different part numbers for the same cable.
One has a eye on both ends of the cable P/N: S800.05.02.02-R2 or 02.S800.05.02.02 (two different part numbers, same cable).
The other cable has a threaded nut on one end, eyelet on the other P/N:  S800.05.02.01-R2 or 02.S800.05.02.01 (two different part numbers, same cable).
If you can't find someone who can build you a new cable, maybe, just maybe Joyner-USA can help. if you can find and contact them.  They're in Mesa, AZ.  Their phone number to their address at 1050 West Main in Mesa  480-882-9612.   Their Riverview and 18th Pl addresses are way out of date.  I was able to get two tires w/rims and two headlights from them in stock.  But that was a few years ago.
  • Thanks 1
    • By nrggaragebuilds
    • By jertex
      I have two questions:
    • By potts
      Goes into gear wont move
    • By OBL
