  • 3 months later...
I need right rear cv axel complete from end to end.please and I need like last week just kidding I’m sure you do all the leg work so if takes a little longer I get it but I cannot find a rear CVC axle for the 650 commando anywhere besides you please give me one coming or can I have one now thank you Tyson wood
Hi Tyson,
The rear cv axle for 650 Commando is still available like yesterday
It is in South Carolina now and if you buy, it will be sent by UPS.
So, if you buy earlier, you get it earlier, no need long time waiting.
Would you please send me email at [email protected] for further discussing?
Casey/ Leaf Asia
2023-05-29
  • 4 months later...
  • 5 weeks later...
On 11/13/2023 at 11:00 AM, rcampneysr said:
I’m looking for passenger side rear axle for Joyner 650 cc Sand Viper. Would you have any available?
Thank you.
Hi Rcampneysr,
I don't have complete cv axle for 650 Sand Viper but I do have both inner and outter cv joint rebuild kits for both rear left and rear right cv axles.
CV Joint rebuild kit photos as attached.
Please send me email to [email protected]  CC: [email protected] for further discussion. Thanks
Casey/ Leaf Asia
2023-11-15
1 hour ago, rcampneysr said:
How would I go about ordering these? Thank you.
Hi Rcampneysr,
I see your email. I will answer you email. Thanks
Have a great day
Casey/ Leaf Asia
2023-11-15
I’ve been watching for your email. Have you sent one that I may have missed? Thanks.
Hi Rcampneysr,
I did answer your email from [email protected]. Looks like the email hasn't been sent to you sucessfully or denied by your email system.
I will try use [email protected] to send email to you again.
Let's keep both sides update here in this forum untill emails can be received with no problem.
Have a great day
Casey /  Leaf Asia
2023-11-17
6 minutes ago, CYJSP2009 said:
Hi Rcampneysr,
Have a great day
Casey /  Leaf Asia
2023-11-17
Hi Rcampeneysr,
I 've just sent you an email from [email protected]. Please kindly check and let me know if you receive the email. Thanks
Casey / Leaf Asia
2023-11-17
  • 2 years later...
On 11/24/2025 at 4:27 AM, Manuel Gavilanes said:
I’m in need of a rear left axel for a Joyner 800cc sand viper
Hi Manuel,
This is casey from Leaf Asia. I am the one created this thread.
Sorry to say that the CV axle you need has been sold out.
There is possibility to get the cv axles be produced. The only problem we need to solve right now  is manufacturer has MOQ requirement ( Minimum Order Qty).  If we can collect  sufficient confirmed order qty, we can proceed the production.
Any interested custsomer is welcome to send me email at [email protected] and let me know which axle you want to order.
Please use Joyner CV Axle Reservatioin  as Email Title.
Good luck
Casey/ Leaf Asia
2025-11-26
    • By nrggaragebuilds
    • By AlphaSerenity
      Hello,
    • By Cliffampranch
    • By Jeff freeman
