instrument panel rubber gasket falling down
it looks like the rubber gasket that is used to weather proof the main instruments ( signal light, speedometer , tachometer, etc) on my Coleman 400 UTV that I purchased in the fall of 2021 is falling down across the instruments. This is obsuring all of the indications at the top and is now affecting the operation of the tachometer since it forms the circle around the tach.  Anyone else had this problem? is this something that I can take apart and fix or is this something that is sealed?
That sounds like it should be a warranty Issue. If that's not working out, then you'll need to look to see if you can access the back of the dashboard.
From there, you should be able to see how to remove the speedometer cluster assembly.
Even if the assembly is permanently sealed shut, it can still be opened, if you're careful.
  • 10 months later...
    • By rtate1050
      I know that this may be a bit outside the forum , but has anyone had any experience with all terrain wheelchairs ? I live on 5 sandy acres in Florida and am currently wheelchair bound. I have a power wheelchair but it doesn't work very well on my property . I.m looking at one that has rubber treads like a tank . It's pretty expensive so I was wondering if anyone had any experience or knows anything about them before I pulled the trigger.
      I do have aa side-by-side but can't get in and out.
      Thanks , Rich
    • By Randyh79
      Is there a way to adjust the brightness of the dash light on aHisun 750 sector?
    • By Jay5
      I’m looking for a quiet side by side for my wife and I. We will do some trail riding but nothing too extreme. We are more geared toward leisure riding since we are in our sixties. We go to Wyoming in the summer and have been looking at the Honda Pioneer 1000, can am defender.
    • By Mark T
    • By Alex
