Dear Friends,
Buy 1 piece: Get 5% discount,
Good Luck
Casey / Leaf Asia
July-07-2022
Dear Friends,
The 2022 Joyner CV Axles and CV Joint rebuild kits will arrive at  Spartanburg SC this week.
To make sure that most of you get the brand new CV Axles and rebuild kits at better cost,  we'd expand the special offer period till the end of July 2022.
Beside the discount listed before, we would offer special discount for CV Boots  ( USD12/ piece)
To proceed order and payment, please contact  [email protected]
  • 3 months later...
  • 5 months later...
16 hours ago, Haley said:
I am looking for a rear axle for a 2007 joyner sandviper 800 cc any suggestions?
Hi Harley,
Please confirm it is a rear left or rear right cv axle you need. Thanks.
I have complete rear left cv axle (SV800.03.02.01.00) photo as attached. If you need rear right cv axle. I have both inner and outter cv joint rebuild kits for 800 Viper.
Further discussion welcome to email me at [email protected]
Casey/ Leaf Asia
2023-05-09
18 hours ago, Cristian Mihuti said:
Hi,
Axles for 08 joyner 800
interested in both sides please. Let me know
Hi Cristian
Please let me know your buggy is 800 Renegade or 800 Viper or 800 Mini Viper.
Please send email to [email protected].  I will check and quote to you.
Casey/ Leaf Asia
2023-05-29
On 6/14/2023 at 9:42 PM, CYJSP2009 said:
Hi TPC,
I have some front cv axle for Trooper. Please refer to attached product photos.
Please send me email to [email protected] for furether discussing. Thanks.
Do they fit 2009 joyner trooper t2
Unfortunately had to part with the SV1100 but Casey is a great parts provider. Got multiple parts from him and even had some made up. Fast responses, fast shipping, excellent to do business with. I wish him nothing but the best he’s got all kinds of parts for different models. Send him an email!
2 hours ago, slagathoar said:
Looking for all 4 for a 2009 Trooper T2. Are these still available?
Hi Slagathoar,
Yes, all cv axles for Trooper are still available.
Welcome to send me email at [email protected] for further discussion.
Casey/ Leaf Asia
2023-08-20
  • 2 months later...
On 11/14/2023 at 1:13 AM, IndianaSandViper800 said:
On 5/9/2023 at 7:11 PM, Haley said:
Has anyone order parts from the Casey guy? Is there a website he has? Is the email posted legit? I need a driver side cv axle for a sand viper 800.. and want to know this is a reliable resource
Hi Indianasandviper800
The mentioned joyner sand viper 800 driver rear cv axle is available. Part nmber for this axle is SV800.03.02.01.00
Please refer to product photos for this axle
Please email me at [email protected]  CC to ylf0302@hotmail.com for further discussion.
Best regards
Casey/ Leaf Asia
2023-11-15
  • 2 months later...
18 hours ago, Meghan Croft said:
Hi Casey I have a Joyner renegade r2 and I need a rear driver side axle how much would it cost and do you have a website or how can I contact you to order
Hi Meghan,
Rear cv axle for Renegade 800 (R2/R4)  S800.03.02.02.00 is still available.
Main specs:  Total length is 582-627 mm ( 25.4mm= 1 inch), Outer spline teeth count: 30 teeth, Inner spline teeth count: 32 teeth.
Please kindly send me an email to [email protected] for further discussion.  Thanks
Casey ( [email protected]
2024-02-12
10 hours ago, Zane Levitz said:
Hi I have a 2009 Joyner sandviper 800cc. I need a left cv axle either both rebuild ends or whole thing if possible?
Thanks, Zane
Hi Zane,
Both complete cv axle and inner and outer rebuid kits are available.  Please kindly send me an email to [email protected] for further discussion. Thanks
Casey/ Leaf Asia
2024-02-23
    • By nrggaragebuilds
    • By mrpro
