I have a 2006 3010 $X$ Kawaski Mule and need a fuel pump relay. The number on the relay is UC-Y001, U-7-2 and it has a Mitsubishi Emblem on it. The Dealer wants $97.00 for this relay. Does any one know if it is possible to cross this over to an aftermarket relay that may be availble in an auto parts store?
Sunman
  • 4 weeks later...
Sunman
Did you ever find your relay?
  • 5 months later...
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
    • By Garjess
      My rtv 1140 won't turn over.  I've jumped the neutral switch, and the brake switch, and checked the ignition switch. I'm not getting any power to the trigger wire on the starter solenoid.  It starts fine with the key on and putting power to the trigger wire on the solonoid.
      Does a 2010 RTV 1140 cpx have a starter relay?
      Does anyone have a wiring diagram?
    • By Kierobi
      Have a MSU 500 that we got from my wife's uncle a while back. We've had it running and hauling around the property but it stopped a few months ago after what I thought was running out of gas and I'm just getting to looking into it.
      Had fuel to the injector but nothing coming out the injector so swapped with new injector and installed inline filter in the supply hose from fuel pump. Tried again and still nothing but noticed this time that I can't hear the fuel pump priming.
      Pulled off the electrical connection and I'm getting 12V to the fuel pump but it won't run. Put it on a test bench and got it to run so put test lamp between +ve and -ve terminals on the connector and nothing. Checked against the passenger seat securing post and get a light.
      Tried chasing the wire back and think that the ground is through the ECU but not 100% sure. Can someone confirm for me? And if it is through the ECU, is the ECU just grounded against the frame or is it wired through to the battery?
      Thanks in advance and hope this all make sense!
    • By Butch
      I have a AXIS 700 EFI Fuel pump pressure stays at 40 psi and when return line is blocked the pressure goes to 60 psi. and wll only run with return line closed.
    • By Jeff freeman
