GBC Motorsports (www.gbcmotorsports.com), a division of Greenball Corporation dedicated to the powersports industry, is thrilled to announce that its tires supported the historic victory of the Bi-Polar Extreme Racing Team/Arctic Cat win at this year’s grueling Baja 1000. This historic win is remarkable in that it was the first time that a side-by-side UTV completed [...]
View the full article
    • By Davescat
      I have an 2019 Caterpillar cuv85. Which is the same as the prowler pro and the tracker800sx and prob many more. What is everyone doing for a lift? I need more ground clearance. I have seen 1 lift available. But is this the only thing I can do?
    • By KMP
      We just bought our 1st side-by-side and wanted to get tips on maintenance items we should address immediately for our 2015 Arctic Cat Wildcat Sport 700 XT.  We are truly beginners and welcome any and all suggestions.  Thank you, we appreciate your help!
    • By harleyman2240
      I am looking at buying a 2008 XT700 Arctic Cat side x side.  Are parts still readily available for these (new) or mostly used on ebay? I have looKed up and found several new parts on the web including ebay,  just not sure if this is a good idea to buy the SXS or not. THANKS
    • By dirtybird
      I am in need of some advice. I jumped started this utv, and since then, it'll idle just fine, but the moment I give it throttle, it starts to bog pretty bad and wants to die. The moment im off the gas, it goes back to idling normal. I'm not sure what the issue could be exactly.
    • By Pilot1996
      When researching the Tracker, I was interested in the 800SX LE. The original sales literature indicated that the LE came with 27x9x14 and 27x11x14 tires. When I went to pick up my Tracker, it had 26” tires on it. I called Tracker before paying for the Tracker and was told they had supply issues and could not get 27” tires. I’m curious to know if anyone has taken delivery of an LE with 27” tires in stalled? I just recently installed 27” tires and am happy with the added ground clearance and beefy look the machine has taken on!
