Coleman 550 2019 Engine/trans locked up. Lost oil out of the bottom.
I was riding at approx 30mph when I heard a very loud noise.  Engine immediately died and coasted roughly 50ft.  There was a trail of oil and now the machine is locked up.  Will not crank or go in to neutral.  Machine has 3300 miles.
Sounds like you need to crawl under and take a look and see what's broken, where its leaking, etc. Unfortunately we can not do that for you over the internet.
Post a picture of where the oil is leaking from and we can help identify the issue.
I have never seen a complete hisun engine sold aside from a few random one off sales on ebay.
Did you get a look and determine its dead? What exactly is wrong with it? There are certainly parts available depending on the exact issue. It you want to swap it anyway I would go ahead and remove it and try to figure out exactly what failed first.
Rod came thru the block.  It’s really bad. Side cover and lower section of engine have a large chunk knocked out.  There’s not internal parts that are usable.   A short block might work.    I found a 2018 complete but I am not sure it will work in the 2019.    I’m told 2016-2018 is different that 2019 and up.
Not sure the exact year for cutoff on engine designs, i think the only major change is going from cabed to EFI. Not aware of any short blocks available. Unfortunately might be better off looking at a new SxS.
    • By Tim n Deb
    • By Chile
      Chile
      Any thoughts ?
    • By Joe Breaux
    • By Aaron Colona
      Just bought a brand new 760 about a month ago. I'm at 20 hours which the book says is when you need to change the break in oil.
      I must be crazy, but I can't find the oil filter. I've googled a million videos...everything seems to be 2019 or lower...and/or a 550.  They all show the filter easily seen by looking in past the rear passenger tire on the engine. There is absolutely nothing there on mine.
      1.there seems to be very little info if you Google a 760, or anything Massimo newer than like 2019.
      2. Does anyone have a current model year 760 that can answer my riddle for me?
