Which snow plow to buy?
Popular Now
By Sidewinder
By MilSurpYinzer
Tire chains for the winter
Bumpers because duh.
Thanks so much!
By KMP
We just bought our 1st side-by-side and wanted to get tips on maintenance items we should address immediately for our 2015 Arctic Cat Wildcat Sport 700 XT. We are truly beginners and welcome any and all suggestions. Thank you, we appreciate your help!
By jugliner
I have a fuel injected UT400 that will start and idle, but surges and sputters at higher speed. It has been sitting for 2-3 months and was fine when parked in garage. I assumed it was a fuel/air problem and pulled the throttle body and cleaned it up. I've ended up replacing the injector, IAC valve, MAF Temp Pressure Sensor, and fuel filter. I've also checked the spark plug, Still surging. I reset the ECU after every component swap.
I plan to pull the throttle body again and look evrything over for any visible leaks, etc.
Any suggestions would be appreciated on next steps. The problem developing after sitting makes me think it should be something simple, but I'm stumped. BTW the fuel was fresh and treated with Stabil.
Thanks.
By jamesxevan
I’ve been eyeing a Hisun 500 soft cab enclosure upper doors setup for my UTV, but I’m really not sure if it’s a smart move. The idea of doors and some protection sounds appealing, but I worry they might just be a flimsy afterthought — weak zippers, thin plastic windows, maybe leaking or fogging when wet or cold. What good is “protection” if it doesn’t seal well? Also concerned about ventilation: with soft doors, does the cab get too muggy or stuffy?
Anyone here use soft-cab doors on a Hisun 500 — did they actually hold up for real riding conditions, or did you end up ditching them for hard doors (or no doors)?
