CCM ROD SHOP introduces its newest line of products for the Yamaha Rhino. The “BILLET MAGNUM†Shifter Knob. The shifter knobs are machined from a solid piece of 6061 aluminum and are polished to a mirror finish. The shift knobs are machined to aerospace tolerances for an accurate fit and unequaled quality. The shifters also
have [...]
View the full article
    • By jertex
      I have two questions:
    • By Stan M
      I just received my 760L a couple of days ago and it's been difficult to shift between gears from the get go. At first I could rock the unit and it would free up for a while but now it's just stuck in reverse and rocking doesn't work. I had the UTV delivered directly from Massimo and there aren't any service centers in my area. Any ideas? Thanks
    • By Big Red Dog
      Bought my 2009 Yamaha Rhino, (fuel injected of course), recently from the original owner. Only had 500 miles and 70hrs. Starts reliably, however, it will not idle but about 50% of the time. Also, when driving slow in low or high, that is to say, relatively low rpms and below about 10 mph, it bucks and almost wants to die..... not smooth at all. However, at speed (say 12-15 mph or more) it runs very well, like it should. Any ideas?
    • By Bigmountainrider
      Hi Team,
       I'm new to the Forum, and I'm looking for your help. I have a 2009 Yamaha Rhino 700 that has stopped consistently charging. Here are the specs and Info I can provide, the Stator and Regulator are new. The Stator does not have continuity to ground on all 3 wires at the engine bay plug. The stator puts out 15-17AC/V at Idle and 38-39AC/V at 2000rpm at both the engine bay plug and the regulator plug. The Battery regulator plug has Battery DC Voltage, when Running the regulator puts out Charging voltage 13.4-15V. I have upgraded/added ground wires from the primary battery to the engine block, from the stock ground wire bolt on the engine to the Chassis and from the secondary battery to the regulator grounding bolt/ground wire. Now the symptoms are it Charges when first started and will continue to charge while driving or at high idle until the machine returns to idle- it will not charge after that, this includes any RPM. If your shut the machine off and restart the process restarts -it will charge until returned to idle. The Machine has and RM Stator and Regulator and a Kimpex Flywheel. The last time it was driven it had an overheating event- unrelated to charging I think, but worth the mention.
      Any thoughts would be helpful, I have the factory Regulator- it was working at the time of replacement- when swapped the same issues occur.
    • By Bryan g
      We see a lot of the UT400 with shift problems, not going into gear, popping out of gear, grinding etc. There  is a bulletin Im sure everyone has saw about adjusting shift cable.  That dont always fix it.  I went round n round with coleman  on couple units. We are a Coleman warranty repair center"AFS Small Engine Repair "   I told them shift lever does not have enough travel .  No amount of cable adjustment  will increase travel . I  extended lever with piece on flat  iron by 3/4 of inch .  This gave shifter enough travel to properly engage into gear completely .  Last couple units to come in for this Coleman sent me a modified shift lever, with longer travel . Problem solved! Also , heads up if you get any new unit ,,,go over and check it out,  grease  all zerks, check air filter for being in backwards, check wiring harnesses for rubbing on rotating parts,  brake hose  routing , make sure not touching exhaust .  These are just  few of the more common failures I see .
