so this thing is a real turd i have gone through so much im ready  to junk it and live a few extra years but  one last chance  it use to run but now it just sucks money  i replaced the starter clutch and it still is doing the same thing just spinning does anyone think it might be the starter is ti weak to turn it over
  • Hisun .500 changed the title to 2008 hisun 500 utv starter spins but wont turn the motor over
You sheared the key on the crank you have to open up the side of the motor on the passenger side there'd be a fan then another cover with the magneto then the key way will be right there on the starter gear! It's a metric woodrife key! Best bet is to buy it on Amazon
On 5/12/2023 at 7:15 PM, farmer99 said:
You sheared the key on the crank you have to open up the side of the motor on the passenger side there'd be a fan then another cover with the magneto then the key way will be right there on the starter gear! It's a metric woodrife key! Best bet is to buy it on Amazon!
Checked that so it was the starter clutch
    • By Hoppy one
    • By esmarkey
      Hi, I purchased a used Cub Cadet 750 Challenger that seemed like the belt was slipping so I put a new belt in.  It still acts like the belt is slipping but now I am thinking it is the clutch?
      Can the clutch be rebuilt?
    • By Garjess
      My rtv 1140 won't turn over.  I've jumped the neutral switch, and the brake switch, and checked the ignition switch. I'm not getting any power to the trigger wire on the starter solenoid.  It starts fine with the key on and putting power to the trigger wire on the solonoid.
    • By AaronD1982
