2015 Hisun Strike 1000 Over heating issues
By rich isaacs
got a 2019 articat prowler, it will only rev to 3800 rpms then says limited rpms . have switched gauge cluster with another machine. it worked fine in other machine but the other machines cluster and ecm did the same limited rpms.
By Chile
Chile
By Geneg
I am actively looking for an oil filter for my Lowe’s branded Axis x550. Lowe’s sold me a spin on filter but every video I’ve seen shows a cylinder filter. Of course Hisun’s website is a year behind not listing anything 2025 and my searches have turned up nothing. Does anyone know what filter I need ( cylinder or spin on) and where I can find one?
thanks
By Joe Rizo
Hello All,
1. Fuel pump (new)
2. Fuel sensor (new)
3. Fuel injector (new)
4. Battery (new)
6. fuses (12v to all)
13. replaced air filter
By Rschrem
Hi, my 2010 Hisun will crannk but comes to a stop and only clicks. It has new battery and solinoid. Battery connections all seem good. Any ideas what the problem is?
