Massimo T-Boss 410 Starter Spins But Does Not turnover
Popular Now
By carbdoctor
I have an 850. It’s been overheating. The electric fan is not kicking on. I see the temperature switch going into the radiator, but there’s no wire plugging in to it or none to be found in the area. i’m thinking I might’ve hooked on a branch and it ripped out the harness on that part. Does anybody have a picture or no where that plugs into on the harness? On the top of the firewall, I did notice some plugs that have nothing plugged into it. I was wondering if it’s a harness that goes from there down to the radiator that was pulled off
By rdc
By Garjess
My rtv 1140 won't turn over. I've jumped the neutral switch, and the brake switch, and checked the ignition switch. I'm not getting any power to the trigger wire on the starter solenoid. It starts fine with the key on and putting power to the trigger wire on the solonoid.
By MilSurpYinzer
