Power Source for RTV900
Popular Now
By Rmillerdesigns
By Surfalia
Just purchased this Old Hisun and it included with a box with a brand new EPS kit. I found YouTube University installation videos and it looks doabke, but maybe the kit is made for newer models because mine doesn't have any extra open plug and play wires I see in the videos that woukd allow me to seamlessly connect the EPS wiring harness too. Has anyone ever retrofitted an EPS kit to a 16 year old model?
Thank you for any usable input offered.
Sincerely,
Surfalia
By darth vadner
I have a 2019 hi sun 750 I parked it in my garage last fall and about a month later I went to ride it and I had no power but the battery shows good. I’ve taken the ignition switch out and cleaned it. I cleaned the battery terminals and replace the main relay all my fuses are good. I still show strong battery but get no power, can anyone help or have any ideas? I have yet to find any wires chewed up like from a mouse or anything all the wiring looks good.
By Jamesshoop1
This was happening to me regularly with the original battery pack, I would drive a few yards and power cut to the motor, no error code, dash works, lights etc, just no drive. Brake lights not on so I don’t think it’s a switch thing. Sometimes it would go back to normal after a few day sitting in the barn. I ended up changing to lithium ion battery 100amp 48v and the problem completely went away for two months so I figured it was something worth the old battteries. Now it’s doing the same thing again, I’ve removed every main electrical connection, cleaned it good, and put it back together. Battery is at100 percent and good voltage. What is interesting is it doesn’t matter how much power I’m drawing, if I’m just creeping along in low or flooring it in high it stops after the same amount of time, about 7 seconds. If I let go of the acceleration right before the 7 seconds I can keep driving like that indefinitely but obviously that’s pretty annoying. Or if I switch immediately to reverse I can back up and go back to F without cycling the key. Has anyone else run into this? It really seems like a safety switch issue to me but unsure what else to check.
By nowgrn4
First post. Just got gifted my 94 year old MIL's Mule 550. She can no longer use it and gifted it to us to putt around exploring the 710 sq mi Natl Forest we live in. It has had a long hard life at her horse farm with 2,438 hours on it and very little Maintenace. I'm doing fluids/filters now and need to do a valve check. Does anyone have the specs? Thanks for any help.
